Fresh Swap Wont Start....
Old Apr 8, 2009 | 10:46 AM
brandoom's Avatar
An Hero
Icon2 Fresh Swap Wont Start....
I know i forgot something...
Fresh SOHC ZC from Hmotors. Cranks but wont start.
Help me out guys, what did i forget?
I know it can be a lot....
Old Apr 8, 2009 | 11:23 AM
spoonfedcrx's Avatar
Default Re: Fresh Swap Wont Start....
What model car is the motor in? Did you have to convert to MPFi?
Are you getting spark? Fuel? Is the timing right?
All your grounds ok? Is plug wire firing order correct?
Is your #14 fuse blown?
Does it have gas?
Old Apr 8, 2009 | 11:27 AM
brandoom's Avatar
An Hero
Car is TURNING OVER but NOT firing.
Originally Posted by spoonfedcrx
What model car is the motor in? -90crx Si
Did you have to convert to MPFi? -No
Are you getting spark? -Yes
Fuel? -Yes
Is the timing right? -No timing lighht
All your grounds ok? -Thermostat/Transmission/Valve Cover grounds all connected.
Is plug wire firing order correct? -Firing in 1-3-4-2 from bottom left clockwise.
Is your #14 fuse blown? -No
Does it have gas? -Yes
Furyof4's Avatar
1st thing to check is always the thermostat ground. Soo many people forget to tighten it down.
Old Apr 8, 2009 | 11:37 AM
brandoom's Avatar
An Hero
i know this, thermostat ground is connected, #14 fuse is in working condition.
Old Apr 8, 2009 | 11:46 AM
Furyof4's Avatar
Ok just checking.
I would go through the steps in this thread from the FAQ.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Old Apr 8, 2009 | 12:12 PM
douglaslovin's Avatar
my dohc zc came from hmotorsonline and the dizzy firing order was backwards. /shrug
Old Apr 8, 2009 | 12:49 PM
brandoom's Avatar
An Hero
sorry i must be tired that is not making sense to me :D
Old Apr 9, 2009 | 06:17 AM
Think he's saying the plug wires were on wrong at the distributor.
I was referring to mechanical timing. Crank and cam aligned right.
Also Ive seen some injectors all gummed up from sitting for years. Swap your si rail and injectors on.
Compression test?
Old Apr 9, 2009 | 06:25 AM
aaronhume's Avatar
are you getting spark, are you getting fuel?
for fuel you can probably tell if you take a spark plug out, if it smells like gas.
for spark, just put a screw driver in a spark plug wire, hold it near a ground, have someone crank the engine over.
Old Apr 9, 2009 | 09:53 AM
Smokinsax's Avatar
The Boot
i would defiantly check the timing (rotate the crank till the marks are TDC and everything is lined up) and firing order on the plug wires.
I've had this problem on more than a few setups
Old Apr 10, 2009 | 12:36 AM
brandoom's Avatar
An Hero
Every ground has been checked and rechecked.
Motor is from HMO. Steve said he checked compression. Im going to check it again tomorrow.
Each spark plug has gas on it after cranking. So there is fuel getting to each cylinder. Checked spark plugs and there is a strong white spark.
Thought it could possibly be too much fuel so i swapped the fuel pressure regulator, to no avail.
Swapped Intake manifold, fuel rail, and injectors to stock A6, thinking it may be a problem there.
I really dont think its timing. Even if it was way off, It should ignite and turn off. Or run like ****.
There is fuel, spark and every fuse is fine.
Checking compression tomorrow. Anything else you can think of?
Car crank and cranks, but wont ignite. Halp!
Old Apr 10, 2009 | 12:53 AM
~sp33~'s Avatar
EFB055
Your compression would have to be terrible for it not to start. Also i think your right about the timing.
I think it's been said before, but have you checked the distributor leads are heading to the right cylinders?
Old Apr 10, 2009 | 07:22 AM
rpaul's Avatar
does your car have an existing alarm that might be not allowing it to star?
Old Apr 10, 2009 | 10:13 AM
All-Motor-Junkie's Avatar
firing the wires as so 1 3 4 2
dizzy engine ie bottom left clockwise 1 3 4 2. is this not correct?
(3 4) 4 3 2 1
(1 2)
Old Apr 10, 2009 | 10:50 AM
CRX=MC2's Avatar
When I did myobd0 to obd1 swap on my old 1990 Si harness, it had old weak-sause wires and at some point and palce cracked. killing the conections to my ecu. Try by-passing the dizzy wires right to the ecu! you will need to lookup your wire specs! They can be found here on h-tech... good luck!
Old Apr 10, 2009 | 11:07 AM
tek24's Avatar
sounds like u got fuel issues...
Old Apr 10, 2009 | 11:31 AM
possible, but fuel is deff getting into the cylinders, and multiple failed attempts at starting the car shows fuel is getting to the cylinder, its NOT flooded we checked last night, if anything its slightly richer then it should be, in this case wouldn't the car at least fire and run like ****? until the a/f ratio is normal?
Old Apr 10, 2009 | 01:11 PM
bump~
Old Apr 10, 2009 | 01:41 PM
linnhatch's Avatar
its ur dizzy.. or a bad connection to the dizzy.. get a new 1
Old Apr 10, 2009 | 02:38 PM
93formula's Avatar
lets see a pic of your dist and wires, if your getting spark at the plugs and fuel in the cylinders sounds like wrong firing order.
Old Apr 10, 2009 | 03:10 PM
one of the wires inside the dizzy was ****ed up but its runnin now and 1 sensors wasent plugged in running fine now with no CELs just need to bleed cooling system :D thanks for input
Old Apr 10, 2009 | 03:24 PM
brandoom's Avatar
An Hero
Success!
Old Apr 10, 2009 | 03:33 PM
brandoom's Avatar
An Hero
Ill have the build thread up soon. Nothing special, but maybe someone can learn from my mistakes hahaha.
Thanks guys!
pvt_awol
Oct 14, 2007 12:25 PM
TOFU.man
May 30, 2004 10:54 PM
racedoutsi
25
Mar 17, 2002 06:05 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
[626]95-GSR
Feb 14, 2002 03:11 PM
