FS: SPC BALL JOINT CAMBER KIT for TL/CL/TSX/ACCORD/CRX/CIVIC
brand new SPC ball joint camber kit
These are high quailty balljoints
3 degrees of adjustment
$120 SHIPED
Acura
CL
1997
Upper
Upper Ball Joint
FRONT SUSP~ADJUSTABLE~MINUS 1-1/2 DEGREE TO PLUS 1-1/2 DEGREE CAMBER
Acura
CL
1997-1999
Upper
Upper Ball Joint
Acura
CL
1998-1999
Upper
Upper Ball Joint
Acura
CL
2001-2003
Upper
Upper Ball Joint
Acura
TL
1995-1998
Upper
Upper Ball Joint
Acura
TL
1996-1998
Upper
Upper Ball Joint
FRONT CAMBER - ADJ SLIDING BALL JOINT~FROM MINUS 1 1/2 TO PLUS 1 1/2 DEG OF CHANGE~USE BALL JOINT PRESS TO INSTALL THIS KIT~4 WHEEL ALIGN
Acura
TL
1999-2005
Upper
Upper Ball Joint
Acura
TL
1999-2006
Upper
Upper Ball Joint
Acura
TL
2007
Upper
Upper Ball Joint
FRONT SUSP - ADJUSTABLE - MINUS 1-1/2 DEGREE TO PLUS 1-1/2 DEGREE CAMBER
Acura
TL
2007-2008
Upper
Upper Ball Joint
Acura
TSX
2004-2005
Upper
Upper Ball Joint
Acura
TSX
2004-2006
Upper
Upper Ball Joint
Acura
TSX
2004-2007
Upper
Upper Ball Joint
Acura
TSX
2004-2008
Upper
Upper Ball Joint
Honda
Accord
1998-2002
Upper
Upper Ball Joint
Honda
Accord
1998-2005
Upper
Upper Ball Joint
Honda
CRX
1988-1991
Upper
Upper Ball Joint
Honda
Civic
1988-1991
Upper
Upper Ball Joint
Honda
Odyssey
1995-1998
Upper
Upper Ball Joint
$120 SHIPED
Acura
CL
1997
Upper
Upper Ball Joint
Acura
CL
1997-1999
Upper
Upper Ball Joint
Acura
CL
1998-1999
Upper
Upper Ball Joint
Acura
CL
2001-2003
Upper
Upper Ball Joint
Acura
TL
1995-1998
Upper
Upper Ball Joint
Acura
TL
1996-1998
Upper
Upper Ball Joint
Acura
TL
1999-2005
Upper
Upper Ball Joint
Acura
TL
1999-2006
Upper
Upper Ball Joint
Acura
TL
2007
Upper
Upper Ball Joint
Acura
TL
2007-2008
Upper
Upper Ball Joint
Acura
TSX
2004-2005
Upper
Upper Ball Joint
Acura
TSX
2004-2006
Upper
Upper Ball Joint
Acura
TSX
2004-2007
Upper
Upper Ball Joint
Acura
TSX
2004-2008
Upper
Upper Ball Joint
Honda
Accord
1998-2002
Upper
Upper Ball Joint
Honda
Accord
1998-2005
Upper
Upper Ball Joint
Honda
CRX
1988-1991
Upper
Upper Ball Joint
Honda
Civic
1988-1991
Upper
Upper Ball Joint
Honda
Odyssey
1995-1998
Upper
Upper Ball Joint
SPC IS MADE IN USA
http://www.spcperformance.com/
Specialty parts corp or something like that
they are known for quailty camber ball joint kits way before this skunk/ectt crap
LagunaSecaEG
11
Sep 3, 2006 07:01 AM
