Shifting Issues Pass 3000 rpm
Old Apr 8, 2009 | 05:06 AM
d-yup's Avatar
Default Shifting Issues Pass 3000 rpm
I have a stock 94 gsr tranny that refuses to go into gear anytime I'm above and around 3000 rpm.
Can this be the result of an old clutch or more of a serious internal tranny problem?
Old Apr 8, 2009 | 07:09 AM
Top Speed's Avatar
Default Re: Shifting Issues Pass 3000 rpm
the synchros are bad
Old Apr 8, 2009 | 07:26 AM
d-yup's Avatar
I realize this problem on the day I accelerated to 7000 rpm in first gear to pass a park car that was in my lane.
Would this be enough to create this problem of having bad synchros?
Old Apr 8, 2009 | 10:06 AM
mouab18c1's Avatar
does it grind or anything? do your gears pop out? check your tranny fluid level
Old Apr 8, 2009 | 11:34 AM
d-yup's Avatar
Will check fluid levels, and it does grind sometimes after that incident but will not pop out of gear. However it does whine upon start up and acceleration :s
Old Apr 9, 2009 | 07:05 AM
mouab18c1's Avatar
you probably busted something then
Old Apr 9, 2009 | 07:37 AM
Zappythebum's Avatar
this happened to me on the freeway when i was driving once.
Order of occurance:
--Accelerated to 5000 in third
--Tried to shift to 4th [Wouldn't let me shift until 3500 rpm]
--Realized my clutch was ground to a nub by the previous owner
--Got that **** replaced
Could be similar to my problem, also when the mechanic was tearing my tranny apart and released the plates a couple shredded pieces of clutch fell down from the lift. So, you could have broken something in the plates like i did.
Hope it helps
Old Apr 9, 2009 | 08:21 AM
HondaTom87's Avatar
Same problem in my brother 2000 si... replaced the clutch and fluid and now it shifts like butter... before changing any of the internals of the trans I would first check on the status of the clutch.
hitting the rev limiter in first shouldn't blow your syncros... that usually happens from a missed down shift. (going from fifth to second)
Old Apr 9, 2009 | 09:41 AM
d-yup's Avatar
That sounds a bit more relieving, I'll have the transmission removed and check up on the clutch.
Thanks for the heads up!
Old Apr 9, 2009 | 09:47 AM
HondaTom87's Avatar
post some pics of your clutch when you remove it
Old Apr 9, 2009 | 10:59 AM
d-yup's Avatar
Yup, will keep you guys posted once I get that clutch out.
Old Apr 9, 2009 | 11:55 AM
rufridn's Avatar
This happened to me and I replaced the clutch.
Zakaria Ism
Transmission & Drivetrain
Apr 26, 2016 07:51 AM
lude98SH
Jun 20, 2005 07:32 PM
ChillOutWayne
Jul 31, 2004 10:35 PM
Kyles ej1
Jun 30, 2004 04:42 PM
not so civic
Feb 5, 2002 12:16 AM
