99 Accord, Cruise Control Problem
the car is a 99 v6 sedan. the cruise control doesnt work... no light in the dash, no light on the butten when pressed, and the fuse is not blown. anybody have a good wiring diagram of the cruise control system or advice for this problem?
is it a simple 2 wire switch? do i just pry it out from the dash where it sits or is it bolted/screwed in?
the last thing i did to the car was turn off the "maintenance required" light(ya kno where you hold the odometer reset and turn the ignition)
I'm not allow to post scans, not to mention the scan/print PC is offline until I reinstall OS, but if it is not too complex I could redraw it in Visio and post that. Maybe a day or 2 though as I'm working to get the H2B out of the garage and the B20 back in.
