How much WHP do you think...
Old Apr 7, 2009 | 11:11 PM
Nicks95GSR's Avatar
Icon2 How much WHP do you think...
So how much WHP do you think I could reach w/ my 95 GSR. With the following mods?
Eagle Rods with Wiseco Pistons(Specs: 81.5mm-11.5:1/RINGS* (KIT) WISECO PISTON ). Im bulding the head with blox stage 2 cams, AEM Cam Gears, ARP head studs, Omni Power Intake And Exhaust Valves, Titanium Retainers, and Valve Springs. Tunning on Hondata s200. Boring the block and a 3 angle valve job. Oh, 70mm throtle bodie, I/H/E. Anyone running a simmilar setup?
Old Apr 7, 2009 | 11:26 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: How much WHP do you think...
190-200hp i,h,e and cams make most of the difrence when making power look into port matching a aftermarket intake manifold to your 70mm tb.
Old Apr 8, 2009 | 05:47 AM
BDaTurboTeg's Avatar
might as well throw a turbo in there and make that much more power :-P
but prob the 200 range sounds about right....thats what i probably would expect
Old Apr 8, 2009 | 05:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Take it to a dyno and find out.
Might want to ask in the All Motor forum.
Old Apr 8, 2009 | 06:36 AM
Schister66's Avatar
Man U FTW
One important thing to note is that there is a fairly sizeable difference in dyno numbers depending on which kind you use. They are merely a tuning device. The real way to check your power is by honing your skills at the track and posting 1/4 times and trap speed. Some people like to brag up dyno numbers and use them as an absolute truth, but in fact, they mean very little.
Old Apr 8, 2009 | 07:06 AM
Community Builder
Probably the only TRUE dyno number would be that from an engine dyno, but even those probably vary.
To get a real sense of how much power your parts and tuning have added, you would need to a do some baseline runs on a dyno with the engine in stock form, then do your upgrades, and go back to the same dyno for tuning, preferably with similar temperature/weather conditions.
Old Apr 8, 2009 | 09:32 PM
Nicks95GSR's Avatar
Thanks guys!
MidnightAuto
Dec 24, 2011 05:45 AM
P12 EG6
71
Jan 20, 2009 06:56 PM
defrank
49
May 7, 2008 08:52 PM
AnthraxVX
Aug 24, 2006 10:05 AM
JDM CRX
Mar 4, 2003 02:13 PM
