HELP: F20c Into Civic or EK
Can anyone give me more info on whats required to do this I know alot of Fab work and all but what really is needed asfar as that? Any info will help let me know thanks!
Some people make their own mounts , use a K series trans, get a clutch to work and then wire it up.
I chose to use InlinePro's F2k kit. Comes with mounts, custom flywheel, halfshaft adapter, midplate.
Uses a custom axle, but you can order them from DSS and they are no more expensive than any of their regular stages.
You have to drill through the block housing in 2 spots and grind down the back in a small area.
The kit is not released to the public yet as mine will be one of the first. After its up and running, more info will be released. Hoping to have the car finished, dyno'd and track tested by next weekend.
here is a pic from the mock up :
yeah talk to inline pro, i stopped by yesterday and christian showed me the kit installed and it was so dope. They know their ish, so they'll be able to help you figure out stuff.
H2B-EK4
Oct 21, 2009 06:03 AM
