trans fluid change 90 crx
Old Apr 7, 2009 | 08:30 PM
brandoom's Avatar
An Hero
Default trans fluid change 90 crx
just put in new ZC into car, the trans filler bolt is super tight and easily going to strip, any other holes you can full through like the h and f series? any helo greatly appreciated. going to try removing rear mount to push motor down a bit so a socket+wrench will fit on the plug. thanks in advanced!
Old Apr 8, 2009 | 05:35 AM
sleepingciv's Avatar
Default Re: trans fluid change 90 crx
u can use the reverse switch hole or the speed sensor hole.
if the trans is empty it takes 1.9 quarts of oil
Old Apr 8, 2009 | 05:38 AM
crxblues's Avatar
just like sleeping said use the reverse light switch hole and fill with honda genuine manual transmission fluid.
Old Apr 8, 2009 | 06:37 AM
aaronhume's Avatar
when you do want to get the bolt off, i have found that the best tool is a good ratcheting wrench, but they are like $80-100 for a set of 8 of them at sears (not the big clunky ones, the polished looking ones) as long as you have the wrench straight on the bolt you can put a ton of pressure on it. i usually end up kicking it to break the tranny fluid bolt loose heh... not the best method, granted.
Old Apr 8, 2009 | 06:42 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
I would recommend a true tranny flush (as in drain, add new fluid, drive it and repeat). No matter which hole you use to drain (even the actual drain plug) it will leave a considerable amount of the old fluid in there.
Old Apr 8, 2009 | 09:28 AM
CRX=MC2's Avatar
The bolt that looks like a cap on the top of the trans, under the starter or next to it. I think It holds down a shift link spring. It would work as a fill point I think!
bad 91 teg
Feb 1, 2011 04:09 PM
thanh4o8
Sep 17, 2008 12:06 PM
JdM_RACeR07
Dec 5, 2006 03:49 PM
92civiclx
Jun 30, 2003 01:00 AM
highmilehatch
Jun 7, 2003 01:12 AM
