Lighting HID/Xenon kits, Retrofits and Associated Topics
My dim lights
Old Apr 7, 2009 | 07:15 PM
OrangeTeggy's Avatar
Default My dim lights
My dim lights in my integra are weak. And theres a ton of pot holes and rough spots, dead animal. You get the idea.
Whats something i could use so I can actually see when my brights arent on?
Old Apr 8, 2009 | 05:18 PM
TunerN00b's Avatar
Default Re: My dim lights
Is the lens hazy / cloudy? Replace / resurface it to restore the output.
Old Apr 8, 2009 | 06:34 PM
so clean it basically?
Old Apr 9, 2009 | 12:03 PM
TunerN00b's Avatar
Er, more than that.
Using plastic or metal polish (its abrasive) you take down the outer layer of the plastic until you get a clear lens again. There are some kits available at parts stores with plastic polish specifically for headlights.
You can start by swishing rubbing alcohol around the inside after removing it from the car (take bulbs out), to see if its just buildup on the inside. If that doesn't help much, then you can move on to resurfacing it.
Old Apr 10, 2009 | 01:57 AM
98civdx's Avatar
Master Detailer
do that and get osram night breakers or, philips.
Old Apr 10, 2009 | 03:17 PM
what if I just got hids
Old Apr 11, 2009 | 06:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
HID in stock Integra projectors is junk. Almost all the light hits the ground about 50-100 feet in front of the car - not nearly far enough out to see obstacles on the road at night at normal road speeds. At 40 mph you travel 100 feet in less than 2 seconds, which is not enough time to react to and avoid something on the road.
Johnmadsen
14
Dec 19, 2017 01:07 PM
snoopaloop986
Feb 15, 2012 10:11 PM
Diegolude
Jan 25, 2003 12:23 PM
OneThirtyEight
Jun 22, 2001 07:30 AM
