FS: LS Parts, Strut Tower Brace, Drag Slicks, Chipped Computers...
Email me at backpurge@yahoo.com with any questions or if you want to make an offer to anything. Don't PM me on here because chances are I won't see it for a month since I'm on here, but don't login super often. All items are located in Crest Hill, IL (just north of Joliet). Would prefer local pickup for all items.
Craftsman 1/2" Air Impact Gun. Never used but it does have some dings and scratches from sitting in my tool box. Model # is 875.19864 . New is $179, asking $125.
Innovate OpenTune OBDII Interface. This allows you to datalog any OBDII vehicle using Innovate's free software. Can be daisy-chained with other Innovate products. New this goes for $149, asking $100.
Innovate LM-1 Wideband and LMA-3. LM-1 wideband control box and LMA-3 multi-sensor datalogger. Logs 3-bar MAP, EGT, acceleration, RPM. Only comes with power cable to wire up to 12 volt source, no o2 sensor or accessory cables (they can all be bought on Innovate's website though). New this goes for $399, asking $200.
Moate's APU1 AutoProm Package, BURN2 chip burner. The APU1 AutoProm will let you chip burn/read, datalog, and realtime emulate. New this goes for $329.00, comes with all cables and extra chips. Also included in this package is BURN2 chip burner, which has the same burning functionality as the AutoProm but without datalogging or emulation, great as a backup or just in case there's any software compatibality issues with your tuning software. New this goes for $89. On top of the burners you also got Moate's HondaLog to datalog via USB on your chipped computer. Also comes with some Ford chips to program OBDI Ford vehicles. New this package is over $425, asking $300.
(4) Type K thermocouples. Used for an hour to get some data. They come with the stainless fittings to thread into a header. Asking $150.
Pair of Hoosier 225/50/16 drag radials, unmounted. Tires only have dyno time and 2 passes on them. Tires by themselves are $189 a piece new. Asking $200.
Chipped computer with adapter harness. Came out of a '96 Civic with non-vtec B-series with stock harness. No clue on the code of the computer but it worked in that setup using Crome no problem. Came out of the vehicle working great. Asking $100.
This stuff came off of a LS motor I received from HMotorsOnline.Com. Oil pan and intake manifold with throttle body. Make an offer.
Ground Control extended strut caps. Never used. 'Relocates shock upward 24mm to allow extra suspension travel. ONLY FITS Ground Control coil-over kits.' Was designed for the Koni Yellows so it has the 12mm shaft. One of the nuts is missing. Asking $100.
Edited the listing and deleted items that have been sold. Everything you see in the first two posts are still for sale!
Hey what are the numbers on the inside of the transmission? like I want to see if its a gsr trans or not? give me a call or text thanks if its a gsr ill pick it up tomorrow i picked up some of the parts you had for sale today
All PM's replied to.
I took a look at the transmission. It's a YSK-1 Acura Integra cable transmission.
Updated the post. Sold the wheels that the slicks were on, transmission and chipped P05. Everything listed is still for sale!
