89 Civic SI Hatchback Sunroof Drain Clogged
Old Apr 7, 2009 | 02:58 PM
mokris's Avatar
New User
Default 89 Civic SI Hatchback Sunroof Drain Clogged
Anybody know how to clean the sunroof drain that has become clogged? I understand the drain line leaves the sunroof well in the center rear and goes down one of the sides (which?) and ends up in front of one of the rear wheels (which?). What is the best way to unclog it?
Old Apr 7, 2009 | 03:37 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: 89 Civic SI Hatchback Sunroof Drain Clogged
They go down both sides behind the front wheels. I've never had one clogged, but I would assume you could snake them out.
Old Apr 7, 2009 | 03:38 PM
LudeEFv2.4's Avatar
Were they different on CRXs and Civics? I have a 90 Si hatch.
Old Apr 7, 2009 | 05:00 PM
shaggyeg6si's Avatar
This happened a couple times on my hatchy. The back drain lines made the bigger difference, they are on the back side of the body, on the side. you can kind of reach them from the beauty panel that covers the tail lights on the inside.
Old Apr 7, 2009 | 05:01 PM
I was able to reach mine by reaching up underneath the rear bumper.
Old Apr 7, 2009 | 05:05 PM
Crx Jimmy's Avatar
use a air compressor and blow the lines out, usually works
Old Apr 7, 2009 | 05:09 PM
nico91civic's Avatar
X2 air compressors, takes 2 seconds works awesome
Old Apr 7, 2009 | 05:18 PM
pinks11's Avatar
just cleaned it out for a friend of mine usng an air compressor as well. Seems like the only thing that will do the job.
Old Apr 7, 2009 | 05:41 PM
scottmog's Avatar
i did this when i removed my sunroof tray just for the hell of it. worked perfect.
Old Apr 8, 2009 | 06:33 AM
was just thinking about stuff, if you dont have access to a compressor you could try to rig a can of air duster stuff, wrap tape around the nozzle till you can get a good seal in the drain then let it rip, might not work as well as a compressor but worth a shot if you dont have one
Old Apr 8, 2009 | 09:13 AM
patrickstar's Avatar
if you use the air compressor, what end would you stick it in? or where
Old Apr 8, 2009 | 11:41 AM
i have a blow gun attachment that i used, you should be able to find one for real cheap something like this http://www.harborfreight.com/cpi/cta...emnumber=42424
whyS0serious
Sep 14, 2009 04:16 PM
florida
Dec 12, 2008 11:55 PM
HankYee
Oct 16, 2005 12:56 PM
shaundesjardins
Jan 19, 2004 04:07 PM
skrappy
Nov 19, 2003 02:01 PM
