valve cover to frame ground
Old Apr 7, 2009 | 07:41 AM
felixjr18's Avatar
Default valve cover to frame ground
hey i jus bought a 97 integra ls and realized that the ground from the valve cover to frame was missing... what all does this effect and my interior speakers get alot of static unless i fade them would this have anything to do with this or do they just need replaced?
Old Apr 7, 2009 | 08:21 AM
HondaTom87's Avatar
Default Re: valve cover to frame ground
the static may be caused from old wiring...
but you should ground the engine it is there to stablize the voltage to the motor... distributor timing, fuel injection, etc...
Get a small piece of 8 gauge amp wiring and two b gauge ring connectors and mount it to the right side of the valve cove to either the radiator support or the frame by the motor mount
Old Apr 7, 2009 | 08:33 AM
dc2teg06's Avatar
You could also hide it by mounting it on the rear of the valve cover, then to the chassis.
Old Apr 7, 2009 | 08:48 AM
HondaTom87's Avatar
yes that too, IMO that is the best way. The less wires seen the cleaner the engine looks
slammeddime
Apr 3, 2013 10:29 AM
its_teddd
Jun 23, 2009 05:59 AM
hpi247
Dec 30, 2007 08:15 PM
EKen9
Jun 23, 2002 05:34 AM
