blox c cams
98+ Spec ITR with bolt ons. What v-tec engagement point should I use with Blox C cams? Will be tuned with Hondata. If there is anything else you need to know just ask.
I have upgraded the valvetrain. I would like to know what most people use. I did have the car tuned and v-tec was set at 5200 rpms. When v-tec engages the change over feels weak. Just asking to see what most people use. I think it should be 5600-5700 range... Maybe I should have said re-tuned with Hondata.....
Good to know you upgraded the VT.
As for VT set point, the tuner should find you the most power. Set points can change from set-up to set-up based on bolt-ons.
As for it feeling weak, I don't know what that means. Most of the un-intiated think you should feel a surge. This is wrong and slow. The more area under the WHP and TQ curves the faster your car will be.
AllmotorGSReg
Jul 22, 2009 06:37 AM
