For Sale Used Full-race topmount pro-am manifold and 4" Downpipe, 44mm tial wastegate
I am selling my full-race pro am topmount manifold, its t3 flanged with 44mm wastegate flange.
USED
http://www.full-race.com/catalog/pro...oducts_id=1220
Design Features include:
# Optimal downpipe placement for true 4.0 inch diameter piping. Constructed with a low angle taper directly at the turbine outlet, the ideal place for a conical diffuser.
# Optimal turbocharger placement allows use of T3 sized turbines.
# Flanged for single Tial 44mm wastegate only.
# Robotically TIG welded.
# Thick wall stainless steel construction.
# Flange surfaces machined flat for a leak free seal.
Full-race B Series ProAm B Series 3.0 in. to 4.0 in. Downpipe
This downpipe is designed to work ONLY with the Full-Race B-series Topmpunt turbo manifold in a EG, EK or DC chassis.
no vband on the end just open 4"
had to make dent to clear my clutch slave cylinder dosn't affect it.
44mm wastegate dump tube
Tial Silver 44mm wastegate (high pressure) . has 14.5psi spring just missing top hose fitting, I was just running in the lower one and lost the top one
total I paid $2275.00
on the setup with sc61 turbo i had ran 10.8@134 gsr cams 26psi
USED
manifold, dp, wastegate and dumptube combo price $1600.00 shipped
USED
USED
alexsracing
May 20, 2009 11:08 AM
Jizzmaster Zero
May 23, 2006 07:14 PM
Flexmyrex
Feb 20, 2003 07:42 PM
