car idles for 3-5 seconds then dies
heres my problem,
Everything on set up is clean and running. When we start the car, it idles for 3-5 seconds then dies but if we try and give it gaz is just die.
2.5 bar motorola map sensor
civic 1995
h22a 1994
ECU P06 tune eCtune PrecisionAutoCanada.com
6 psi boost
Turbo Holset T3 hx35w
intercooler XS power
Kit 'injection de water-methanol
Injecteurs Precision Turbo 880 cc
Ligne 3" complete mandrel
Downpipe 3"
Piping complete intercooler aluminium 3"
Intake ported
Wastegate 38 mm
Gasket intake Hondata
tensionneur H23
piping cx racing
log manifold
Walbro 255
Filtre a essence
Timing belt + balencer belt
The SRS light if always flashing in the dash and the check engine code is for vtec solenoid (code 21)
we change the sparkplug, wire, cap
any help?
we put the stock injectors, ecu and map sensor and the motor ran like a charm but when we put all the goodies back on (880 precision injectors, p06 ectune, 2.5 map sensor) the problem was still there
civic 1995
h22a 1994
6 psi boost
Downpipe 3"
Intake ported
Wastegate 38 mm
tensionneur H23
piping cx racing
log manifold
Walbro 255
Filtre a essence
any help?
we redid the wiring of the map and the problem is still there...we think that the tuner didnt set the map correctly...i think ill just put back my stock ecu, injectors and map and go to a tuning shop and have them test the computer
forgot to say,
This set up was in another car before (civic 1994) and ran with NO problem. I think that the map could be damage or the ECU is **** and i got ****ed by the tuner twice
weird thing is that i cant get them...something with the tuner
anyhow, we put the stock injectors, mpa sensor and ecu and i am going to a different shop
se93
Oct 11, 2002 03:06 AM
