88-91 Civic uprights
Old Apr 7, 2009 | 03:35 AM
13GT3's Avatar
New User
Default 88-91 Civic uprights
Hey guys, I am just looking for some advice. I have a 90 Civic SI that i luv and want to bring back to full working condition. I have done quite a bit of suspension work on it but have found that the lower balljoints are shot. Is it possible to remove and replace the ball joins on their own or should i just go searching for some old but decent condition ones from a wrecker? I havn;t been able to find some aftermarket ones yet but i am still looking. Any help you can offer would be appreciated. Thank you.
13GT3
Old Apr 7, 2009 | 08:59 AM
89EFB20VTEC's Avatar
New User
Default Re: 88-91 Civic uprights
hey man im pretty sure they sell them aftermarket....if i were u, i wud try a Napa....they usually got some aftermarket ish if ur looking for it....if not i do beleive 92-95 civics also have similar ball joints as well...the problem being is if u try to go to a wrecker its more like a hit and run...youlll either get lucky and get a good pair...or they might just go within a matter of days...good luck
Old Apr 7, 2009 | 09:14 AM
aaronhume's Avatar
if you want to replace just the lower ball joint, you need a special tool [you can rent]to press them in/out. if you find a decent set at the junkyard, get the whole knuckle/hub, and it will be cheaper, but a shorter term fix.
Old Apr 7, 2009 | 11:14 AM
wiZCo's Avatar
Stouts 'n' Scotch
It's possible to replace them, and pretty cheap if you can do it yourself. IIRC I did mine a few years back for something like $25.
H22Honda98
Dec 16, 2008 06:04 PM
Supernatural
Northern California (Sales)
Mar 20, 2006 09:06 PM
dgonzals
Apr 26, 2004 02:36 PM
