A little brake question help please
ive got a 95 4dr teg gsr i am wanting to remove the abs system. well my question is.. Is there another honda,acura, i can pull the brake lines off of that will bolt right in or with little modification? also will i need anything else to make this work? Or is my only option just to make new brake lines? Any and all help is apprecitaed. thanks
Integra RS...a couple of civic lines will work, but if you want them all from one car the integra RS from '94 - '98 is the one. Good luck!
True story...the abs integra does not have a prop valve as it is controlled by the ABS unit itself. Also you will have to make one slight mod to one of the RS brake lines as the RS master cylinder has both lines going into it on the right side, while the GSR has one on the left and one on the right. other than modifying one line, the other option would be to buy the complete RS master cylinder and brake booster. Good luck!
743power
Apr 23, 2003 03:19 PM
