OBD1 Vs OBD2 Oil pump on a OBD1 block-
Old Apr 6, 2009 | 02:26 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default OBD1 Vs OBD2 Oil pump on a OBD1 block-
Hey everyone- Im beginning to order parts and am wondering what to do with the oil pump-
A) Purchase OBD1 pump for 135, keep plastics that I have
B) Purchase OBD2 pump for 97, buy plastics for 38- (then sell my plastics) This would be less expensive.
So is there any advantage to the OBD2 pump? By buying the OBD2 plastics, will the top ones that I have (OBD1) bolt right on no problem to the bottom (OBD2) ?
Old Apr 6, 2009 | 05:23 PM
patriot's Avatar
Default Re: OBD1 Vs OBD2 Oil pump on a OBD1 block-
The advantage to an OBD2 VTEC pump is that it's the same as a Type-R so it will give you that few PSI more pressure...
...or you just take out the washer on the relief valve and that's the only difference of a Type-R.
Old Apr 6, 2009 | 06:04 PM
nytosc's Avatar
hm well I really thought I should get a new oil pump- I searched for information on rebuilding them, but all I get is garbage search results from internet brands...
Old Apr 6, 2009 | 06:12 PM
patriot's Avatar
Nah, not worth rebuilding. Unlikely you'll have a problem with a used one unless the engines been neglected, but if you even end up with bad side clearance youll be looking for a new one anyhow.
Old Apr 6, 2009 | 06:50 PM
nytosc's Avatar
Yea I guess its not worth risking it- maybe if this was a ghetto build lol
Just trying to do it right the first time. thanks!
teddy_dc2
Apr 4, 2019 02:12 PM
accordmatt
Sep 21, 2010 11:24 AM
street_ride14
Sep 25, 2008 04:27 PM
EM1_00Si
Jun 10, 2007 09:01 AM
AsianMullet
Jan 22, 2005 05:21 PM
