Wheel bearing for Sir knuckles
As stated, which bearing are correct? I know the si,dx,ex are too small, i think the 90-93 teggy will work but havent seen anyone say yes or know. I just wanted conformation before i order an expensive part
TIA
TIA
go to www.crxsi.com/jdm, look up the part number for the ef8 wheel bearing and then cross reference at online honda or acura dealers or with your local dealer.
I checked for you:
ef8 sir wheel bearing part #: 44300-SF1-004 or 44300-SF1-008
44300-SF1-008 matches an 88-91 prelude or a 90-93 integra
I checked for you:
I checked for you:
I checked for you:
Cool thanks a ton man, good site to keep in mind. I wonder if the outer tie rods match up too...
outer tie rod R 53540-SH3-N10
outer tie rod L 53560-SH3-N10
doesn't make me feel to good about when the time comes to replace them on my ef8 SIR.
I know you can cut the inner (3/4 inch) and use a die to add more thread to make the usdm si ones work . It would be nice to get a bolt on part, but maybe im just to wishful.
OneBadTurboCRV
Nov 23, 2009 11:23 AM
Super79Dave
Nov 12, 2008 08:40 AM
JDogg
Suspension & Brakes
Apr 12, 2008 08:57 AM
