alternator adjusting bolt
Old Apr 6, 2009 | 05:20 AM
almostvtec's Avatar
Default alternator adjusting bolt
i just did the timing belt/water pump replacement on my moms 98 accord lx it has the f23a1 and i reassembled everything the way its supposed to be done. now everytime i drive it the alternator adjusting bolt keeps backing out releasing the tension on the alternator belt. any ideas on what i can do to fix this problem?
Old Apr 6, 2009 | 05:59 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: alternator adjusting bolt
Did you install it correctly?
There's the bolt on the front underneath that has a little metal wing type thing, you slide the bolt through the break and alternator, then through that wing.
Loosely put on the alt's bolt then tighten down the adjustment bolt. Once it's tight crank down on the bottom bolt
Old Apr 6, 2009 | 08:52 AM
almostvtec's Avatar
yes i installed it correctly...ill try that and see if it works
Old Apr 6, 2009 | 09:27 AM
H23 Power's Avatar
also tighten down the upper bolt once its adjusted correctly.
utn
Honda Civic (2001 - 2005)
May 24, 2016 01:20 PM
fslim
Aug 6, 2015 06:18 PM
dviladvct1
Nov 20, 2012 10:31 PM
FBPPrelude
May 22, 2007 12:31 PM
kaoss_11
Jul 15, 2004 12:22 AM
