88 ef b18b1 dizzy wiring help plz
Old Apr 5, 2009 | 10:29 PM
b18swapef's Avatar
Default 88 ef b18b1 dizzy wiring help plz
i have a 1988 civic hatch with a b18b1 swap and this weekend i did a clutch in it and on the test drive my wiring harness got cought on my cv axle and twisted around it. (i know i am a dumbass) but any ways i pulled all the wires back through and they all seemed to be fine i taped up the few that wore threw and then my car started hitting a rev limiter at 3 grand and throwing a code 4 so i check all the wiring to the dizzy and the one big blue wire with the 4 wires and the ground strap in it had some wear spots in it so i taped it all back together and now it wont hardly run so how do i fix/ replace the big blue wire? any help would be awsome thanks.
Old Apr 6, 2009 | 03:55 PM
b18swapef's Avatar
Default Re: 88 ef b18b1 dizzy wiring help plz
i need some help really bad am i gonna need a new wiring harness?
Old Apr 6, 2009 | 05:10 PM
intense4thgen's Avatar
cut the wire back and replace the broken section, clear the codes when you done and you should be good to go
Old Apr 6, 2009 | 06:54 PM
b18swapef's Avatar
i tried doing that but the bare groung wire that is wrapped arounf the 4 wires in the insul is snapped in alot of places
Old Apr 6, 2009 | 08:12 PM
93formula's Avatar
you may as well just get another harness, may be simpler then to repair the one with torn wires.
B18aef
Aug 16, 2016 06:02 PM
Deznuts4u8869
Jun 15, 2007 09:30 PM
Freeltec
Mar 21, 2006 03:01 PM
vtecn8ive
11
Nov 8, 2005 07:56 PM
