Motor mounts for 350 WHP car?
Old Apr 5, 2009 | 07:53 PM
The_Honda_Guy's Avatar
Default Motor mounts for 350 WHP car?
Hey guys, getting ready to build my 94 EX and have a question on motor mounts. I'm wanting to use this car as a daily driver with some track time, so I'm not wanting something that's going to vibrate like crazy, but something that will be stiffer than the stock mounts. I did a lot of reading and it seems like a lot of people like to take the stock mounts and fill the gaps with 3M Window Weld. This seems to be an extremely cheap and easy way to do the mounts without having to deal with all the vibration the aftermarket mounts cause.
Thoughts?
Old Apr 5, 2009 | 08:07 PM
da_dude's Avatar
Default Re: Motor mounts for 350 WHP car?
Do it. I wish I did.
Old Apr 5, 2009 | 08:47 PM
TheShodan's Avatar
Moderator
Stocks been fine for 350whp, but its your call. The vibration will transfer to the rest of the car. period.
Old Apr 5, 2009 | 10:34 PM
blinx9900's Avatar
TRUTH
I used liquid urethane from mcmasters for mine and the car vibrates!
Old Apr 6, 2009 | 12:08 AM
Tony the Tiger's Avatar
I use the energy suspension motor mount inserts... The vibration is there, but there is no sharp "buzz" like some of the aftermarket urethane mounts.
Old Apr 6, 2009 | 02:10 AM
omiehomie's Avatar
some one correct me if im wrong, but i heard if you call hasport directly they have different types of (firm-ness) of mounts that you can get (i.e. street, drag, etc).
maybe give them a call and see what they say...
Old Apr 6, 2009 | 02:46 AM
blinx9900's Avatar
That hold true for just about all engine mount companies, but even the street versions do vibrate your *** a bit vs the race ones vibrating your dash apart!!
Old Apr 6, 2009 | 04:13 AM
I can deal with a little vibration, but I want to keep it minimal as possible. I just basically want something that's going to be a little stiffer that won't tear apart on a launch. I'm thinking that the 3M filled stock mounts may be the way to go for me in this case since the car won't see the track much and will mostly be a daily driver.
Old Apr 6, 2009 | 04:19 AM
black_EM1's Avatar
Community Builder
Community Influencer
I've got the Avid Racing mounts in mine, they're not bad at all.
3M filled stockers are a good option as well.
Old Apr 6, 2009 | 04:21 AM
non-VTEC's Avatar
i dont see what the big deal is with the motor mounts. unless you oem ones are broken they will be perfecly fine.
Old Apr 6, 2009 | 04:48 AM
blaze the chemi's Avatar
I have heard the 3M option is viable, but I have never been in a car with that done to the mounts.
I have done the ES inserts and it's not that bad. The steering wheel vibrates a bit more at idle and you'll know which dashboard bolts are just loose enough, but it helps and still flexes.
Old Apr 6, 2009 | 06:14 AM
hawkturbo's Avatar
whoos the best option for 450 HP cheep way pls for drag porpuse and hit the street some times lol
ahobbs's Avatar
HELLO,GOOD MORNIN'
I use OEM at 415whp and will be using them at 450+. If they tore i would probably buy them again. or maybe fill them. I dont like buying expensive mounts that make me complain about driving my car.
Old Apr 6, 2009 | 06:42 AM
hawkturbo's Avatar
ok what you think oem mount whit energy motor mounts
Old Apr 6, 2009 | 07:39 AM
91whiteZCrex's Avatar
if you get these
http://jhpusa.com/store/pc/viewPrd.a...ct=443#details
They arew 65a street urathane, they do NOT vibrate like crazy i have them. you can barly notice it and i use it on my DD, just my opinon
Old Apr 6, 2009 | 10:48 AM
Turbo_TONY's Avatar
Ive just got the stock mounts but im buying the full-race proAm traction bars that have the "extra" motor mount. Hook it up when at the track and take it off when driving around on the street. Kinda kill two birds with one stone. Traction bars and "a solid mount" for about $400. Just my .02.
Old Apr 6, 2009 | 03:07 PM
adamrg85's Avatar
I also have Avid Racing mounts and I feel little to no vibration, feels almost like stock.
avid mounts are cheaper than most aftermarket mounts and are very good quality and as far as how much power they can handle, I have a friend that uses them in his SFWD race car which makes 700+whp.
Old Apr 6, 2009 | 03:35 PM
mmmbrapND's Avatar
I have inovatives and they rattle everything sooooooooooooooooooooooooooooo much.
Old Apr 6, 2009 | 03:57 PM
shocker911's Avatar
i actully like that the car vibrates...i have inovative mounts with energy suspension torque inserts
Old Apr 6, 2009 | 04:05 PM
I will most likely just take my stockers and fill the gaps in them with the 3M window weld. Since I want to use this car for a daily driver I don't want the vibration that aftermarkets will cause, nor do I want to spend the money on them when I know I won't be happy with them. I've driven cars that had poly mounts and driven ones with the urethane mounts. Although they do stiffen things up they make the car quite a bit more uncomfortable to drive, and this is car I want to be able to drive to meets and such, not something that's going to make me hot and uncomfortable.
Old Apr 6, 2009 | 04:50 PM
GSROWNSU's Avatar
I have the energy suspension inserts in all my stock mounts. The vibration isn't bad at all and they work very well. Cheap too compared to buying complete mounts.
Old Apr 6, 2009 | 04:56 PM
marcj's Avatar
i've got inserts.. noticed a huge increase in torque response once i slapped them in. more torque goes to the ground instead of twisting the motor.
Old Apr 6, 2009 | 05:03 PM
hayn_integra's Avatar
Ive got hasport mounts. It vibrates alot, especially when the motor is cold. But you kinda get use to it... HAHA.
Old Apr 6, 2009 | 05:15 PM
vtec-king's Avatar
i have inovative mounts with avid racing torque mounts...they vibrate but not to bad i don't have a problem with them at all....but use stock mounts and just get the avid torque mounts and you will be fine..
Old Apr 6, 2009 | 06:21 PM
Turbo-LS's Avatar
INSERTS FTW barely any vibration, rock solid motor. probably not as solid as an overpriced billet mount but who cares for that power level. making over 450 and i love my inserts
