need help is this safe d15b2 mimi me
i try to google couldnt fine anything up on it
wen i try to pull out the snow man the screw broke and got stuck in there is this safe
i put everything back together and it started up fine i have another problem my spark plug wire pop out wen i started to test drive it???
so could this be problem?? screw stuck in the oil jet
i know i dont have vtec cuz i didnt take the the snowman out can this be a problem cuz of spark plug wire is poping out... can anybody help me
damn that suck i put everything back together! dat why it stop running and spark wired started to pop out thanx bro really thanxful for this
Are you running the d15 plug wires still?
I believe they are different than D16, but may be modified to get the proper click on the plugs.
Also what head are you using as well as what ecu?
that oil jet on the block comes off pretty easily, maybe you could dab epoxy on top of it and lay a screw on top of it, wait till it hardens and pull it off.
yo this my first time ever doin this type of shyt. im learning as well..
since it was already plug up, i just left it alone, and put everything back together it run hella strong. i just need to change spark plug and wired and pvc valve
the head have stage cam and a tru time gear and the head only had a 100 mile on it
Tracy47
Apr 21, 2015 10:47 AM
vsmftw98
Aug 4, 2009 02:14 PM
