Piston to Valve Clearance in a k20?
Old Apr 5, 2009 | 12:19 PM
seen4ever's Avatar
Default Piston to Valve Clearance in a k20?
Finishing up a new build on my k20. Per the helms manual it appears you need a number of special tools and fittings to use air. Didn't know if there are any tricks similar to the B-series of using a bb to loc the rockers.
Setup is a 12.5:1 piston with stock valve size with IPS k2 cams.
I figure it should be safe but would like the piece of mind. Any help would be appreciated.
Old Apr 6, 2009 | 11:09 AM
seen4ever's Avatar
Default Re: Piston to Valve Clearance in a k20?
bump
Old Apr 6, 2009 | 02:13 PM
sidious141's Avatar
Post this on k20a.org?
Old Apr 7, 2009 | 05:43 PM
seen4ever's Avatar
just trying to get multiple sources of information
spoolinvtec54
Engine Machining & Assembly
11
Nov 10, 2016 09:31 AM
TurboSmith421
Nov 4, 2010 11:57 AM
wingsEK
Dec 23, 2009 12:22 PM
egb18c5
Aug 22, 2007 10:43 PM
