paint removal on a cf hood
Old Apr 5, 2009 | 08:03 AM
moochie972's Avatar
Default paint removal on a cf hood
I picked up a cf oem hood from a guy and the center of the hood is painted red. I don't think it's cleared over because you can feel the ridge where the cf and the red come together. Is there a way to take off this red paint and not damage the clear underneath? He thought maybe I could wet sand it, but I just wanted to check to make sure. Any help would be appreciated.
Thanks!
Old Apr 5, 2009 | 11:20 AM
Hawkze_2.3's Avatar
Default Re: paint removal on a cf hood
Honestly there is no way you're going to get the red off without hurting the clear. Wetsanding will take a loooooonnnnggg time and it could be done, but you would still hit the clear under and around the red.
I would plan on shooting another clear coat if you remove that red. A good size sanding block would help a lot to remove it evenly...
Old Apr 5, 2009 | 02:57 PM
db8SI's Avatar
lol just try small spots with thinners maybe it will come out ... if not then u can just 800 girt the whole bonnet and reclear
Old Apr 6, 2009 | 12:44 AM
db8SI's Avatar
Originally Posted by flycatcher
iam with db8si there,,ill hit with thinner on a small area then $800 grit and maybe just a buff with rubbing compound after that if you get the paint off.
cant buff with 800grit .... gotta reclear ... if u wanna buff use 1500 or 2000 grit
Old Apr 6, 2009 | 06:00 AM
precisionsc54's Avatar
wetsand it off then reclear the entire hood
Old Apr 6, 2009 | 02:32 PM
moochie972's Avatar
Wow, thanks for all the replies! I know I'm gonna have to reclear the hood and all, and I'm in the process of doing some minor body repairs. I'm gonna have the whole car painted soon, I just wanted the red off for now since I traded the guy my stock hood for this cf one and now it's the only hood I can roll with. Think I'll try the thinner idea first and see what happens. Thanks!
Old Apr 7, 2009 | 11:38 AM
Hawkze_2.3's Avatar
Thinner does nothing to cured automotive paint...
Old Apr 7, 2009 | 10:03 PM
db8SI's Avatar
GO GET YOUR FACTS RIGHT ......
thinners will work if the paint he used was from a spray can .. and if it is Laquer also if u sand off the clear on the paint and use thinners it will break down the base coat and will come off
Old Apr 8, 2009 | 08:56 AM
Hawkze_2.3's Avatar
LEARN HOW TO READ AND COMPREHEND....
Real automotive paint does not come from a spray can. Anyone knows that....
Old Apr 8, 2009 | 11:42 AM
mztykal's Avatar
It can if the shop puts it in the can for them.
Old Apr 8, 2009 | 11:43 AM
mztykal's Avatar
If you get solvent it'll eat it away after awhile.
Gun wash will do that also.
Old Apr 8, 2009 | 02:09 PM
Hawkze_2.3's Avatar
Very true, but that's not what he was saying. He said if the paint was from a spray can then thinners will break it down, referring to the weaker off-the-shelf non-catalyzed rattle can paints.
If the OPs hood has regular spray paint on it then thinner will certainly break it up, but if the red is real cured automotive paint then it won't do anything. That's the only point I am trying to make...
Old Apr 8, 2009 | 02:59 PM
OMG enough damn bickering. The guy asked a question and all thats needed was a simple answer.
FreeAlchemist
Honda Civic (2001 - 2005)
Nov 8, 2017 05:10 PM
xTimmyx
Paint and Body
May 26, 2010 10:36 AM
lkailburn
27
Nov 30, 2003 09:22 PM
Goinfasterthanu
Aug 12, 2003 03:49 PM
Calavera
Jul 17, 2003 12:33 AM
