'96 Honda Accord multiple codes...
Old Apr 5, 2009 | 07:30 AM
liberty_bell's Avatar
New User
Default '96 Honda Accord multiple codes...
Hey, I just plugged into my girlfriends car and a couple codes have all popped up in the matter of a day. Her car has always operated fine and then one day, while idling with the break applied the entire vehicle started to shake and the check engine light came on and started flashing. By her account, it operates fine while driving but when stopped the entire vehicle shakes.
The codes I pulled off are:
P0135- o2 sensor heat circuit malfunction
P0700- transmission control system malfunction
P01705-manufacturer control transmission
P0715- input turbine speed sensor A circuit malfunction
P0730- gear ratio incorrect
I'm thinking the o2 was probably a prior active alarm and unrelated to the shaking, and that all her problems are from her transmission. Please correct me if I'm mistaken. But as far as all 4 of the transmission codes appearing, I'm a little confused as to a cause. Any suggestions on determining if it's the transmission itself, the control, or even just the turbine speed sensor? Any advice at all would be appreciated. Thank you.
Jon
Asha79
Mar 10, 2017 12:16 PM
MyDaughtersCar
Apr 11, 2010 07:49 PM
96_Accord
Sep 4, 2009 06:33 AM
pnut
Jul 27, 2003 08:19 PM
