will the exhaust manifold from the DX civic hatch fit right on to the standard hatch motor?
i have the exhaust manifold with the cat right under the engine .. but i want the one from the DX with no cat just the pipe.. will it bolt right on?? also i dont know if i have the DX or STD engine .. how can i tell??
thanks
mike
thanks
mike
ok.. how much for it... also.. i dont know what car i have.. its a 5 spd but yet it has the cat under the motor instead of under the car.. and its faster than my friends DX which has less miles and more performance parts, so im not sure what engine i have.. is there a # i can look for to tell? also arent the STD motors only 8 valve? mine is 16.. but i dont know.. just let me know how much and will it just bolt right on in place of the current one?
mike
mike
if its the same motor then how come one only has 70 hp and the other 90hp??ill check my block for the code...
different ecu program and a restricter plate in between the throtle body and intake manifold
civicracer89 i will take your std manifold off your hands if you are interested im me. i also have a header for sale, im me.
u can have my manifold for free if u find me something else to go there.. i just need a manifold thatll bolt right in its place but has no cat .. i just need the pipe..
mike
also .. is the restrictor plate under the throttle body removable? and what does it look like?
mike
no header will bolt right on i know from experience the piping doesnt bolt up the restricter plate maybe removeable but mpfi is way better
I don't think the STD downpipe will bolt to the DX manifold. The cat outlet is angled on the STD. But you need a pipe that comes up straight to bolt to the DX manifold.
feelsfast
Oct 6, 2004 04:34 AM
wu tang
23
Aug 11, 2002 12:34 AM
