99 accord transmission problems
Old Apr 5, 2009 | 06:27 AM
Dave1821's Avatar
Default 99 accord transmission problems
I have a 1999 accord with the auto trans, all was good till I took the battery loose to install some glow gauges not the trans is acting up taking long time to shift gears and at times shifting hard. The D4 light is (not flashing) any idea's welcome.
Old Apr 5, 2009 | 06:46 AM
YeuEmMaiMai's Avatar
Default Re: 99 accord transmission problems
get it diagnosed and if it is the trans replace it with a HONDA REMAN....too many updates to the unit to trust a trans shop rebuild it properly....
Old Apr 5, 2009 | 09:03 AM
bdmlilburn's Avatar
before you spend money taken it to a shop check the fluid level. also if it needs fluid make sure to use honda z1 atf
Old Apr 6, 2009 | 11:20 PM
CG6Accord8o1's Avatar
yee drain and refill the fluid and reset the ecu and let it idle for 10mins.
bren611
May 16, 2014 09:58 AM
1996accordlx22
Aug 5, 2012 07:30 AM
gmin
May 14, 2011 07:05 PM
mozee82
25
May 19, 2010 05:30 AM
licks
May 9, 2010 04:24 PM
