K20-R build problem, HELP
Old Apr 5, 2009 | 03:08 AM
type_r_teggy's Avatar
Default K20-R build problem, HELP
A friend of mine has a swap k20 in a civic hatch, so he decide to do a budget build...
JDM K20-R motor
K-Pro
R-crew replica headers
custom 2.5inch exhaust
skunk 2 stage 2 cams without valvetrain (dont ask) stock rev limit
OBX ITB's (can't remember the size)
Aeromotive FPR
stock block
the engine dyno at ONLY 200whp fully tuned...
What the hell is wrong??????
Old Apr 5, 2009 | 05:39 AM
EK9 CTR's Avatar
Default Re: K20-R build problem, HELP
Are you able to post a dynograph??? It could help us in pin pointing the problem... What type of dyno was used???
Old Apr 5, 2009 | 08:57 AM
eK24monster's Avatar
Bottom line is... you friend made some poor choices. He has a Bad combo!!
Old Apr 5, 2009 | 08:59 AM
sorry no dyno sheet, dynojet
Old Apr 5, 2009 | 09:20 AM
95civicej1's Avatar
bigger exhuast, lose the OBX itbs, get an rbc manifold.
prolly would make more power.
Old Apr 5, 2009 | 09:36 AM
tagperformance's Avatar
do a leak down and compression check.
Old Apr 5, 2009 | 09:58 AM
Loose the shitty ITB's and put the PRC or RBC intake manifold on and re-tune. Also, make sure the shop/ person tuning knows the K Series.
If you really want to get everything out of that motor... switch to a 3" exhaust, get a better header, and re-tune.
Stock DC5R swaps w/ an RBC, correct length intake, a decent swap header, and a 2.5" exhaust make 212-218 (Dynojet)
type_r_teggy
K Series
11
Feb 26, 2012 04:42 AM
RNbuilt
Feb 17, 2008 11:45 AM
zhan28
Apr 17, 2006 09:35 AM
RACER2BE
15
Jun 25, 2005 11:18 AM
FastKTJ
Sep 15, 2004 10:07 PM
