Replacing main damper bushing on rear trailing arm?
Old Apr 4, 2009 | 08:05 PM
Ldo's Avatar
Ldo
Default Replacing main damper bushing on rear trailing arm?
I'm doing rear brake conversion and notice that the big bushings or dampers on the trailing arms are torn. Can those be replaced? I'm checking the online part stores, and they don't even have a part number for those things.
Thanks for the help.
Old Apr 4, 2009 | 08:12 PM
alscrx's Avatar
Default Re: Replacing main damper bushing on rear trailing arm?
Those are called trailing arm bushings. Yes they can be purchased seperate from honda or any other online parts place.
Old Apr 5, 2009 | 05:24 AM
honda.lioness's Avatar
Ditto alscrx's comments. See the following site for the part number and chatter about the tool to buy or borrow to replace them: http://honda.lioness.googlepages.com...ion#tabushings
Old Apr 5, 2009 | 01:06 PM
sgallagher's Avatar
Did mine with a dead blow hammer.
Old Apr 5, 2009 | 04:35 PM
CRX Toad's Avatar
http://www.performanceforum.com/wesv...nda/index.html
Old Apr 6, 2009 | 10:01 PM
Ldo's Avatar
Ldo
Thanks for the links.
For future reference, the part number for the bushing is 52385-SR3-000. Got mine for $65 each from the local Honda dealer.
With the whole trailing arm outside the car, I was able to hammer the old one out and hammered the new one in with a seal or bearing tool. Just pay attention to the direction and location of the old ones before popping them out. Takes about 30mins to replace both bushings.
I'll see how different the car will behave.
Chef Andre
Dec 15, 2008 01:26 PM
blaak-crx
Suspension & Brakes
10
Jun 2, 2008 05:14 PM
Reelizmpro
Feb 27, 2006 01:31 PM
TeaAddict
Dec 17, 2004 10:38 PM
