sunroof help
ok i own a 95 civic dx sedan. when i bought the car the sunroof was caulked
from the po. i got bored one weekend and took the caulk off to see what the problem was but im still not sure. it dosent sit flush with the roof unless pushed down. and even then it lookes like its missing something around it. iv tried pulling and pushing to get it to open completly but no good. it looks like its sitting on a track that its suppose to be pushed up then slid back. iv tried using white lithium to grease it but that still didnt work. from the inside it looks like several plastic pieces have been broken. theres also some positive and negative wires hanging with connections that went to something.
basiclly wat i want to do is make it to where i can open and close my sunroof without the worry of leaks and all the other pains. so what would you guys suggest???
from the po. i got bored one weekend and took the caulk off to see what the problem was but im still not sure. it dosent sit flush with the roof unless pushed down. and even then it lookes like its missing something around it. iv tried pulling and pushing to get it to open completly but no good. it looks like its sitting on a track that its suppose to be pushed up then slid back. iv tried using white lithium to grease it but that still didnt work. from the inside it looks like several plastic pieces have been broken. theres also some positive and negative wires hanging with connections that went to something. basiclly wat i want to do is make it to where i can open and close my sunroof without the worry of leaks and all the other pains. so what would you guys suggest???
drewzilla
Nov 11, 2006 06:10 PM
monkmonkman
Mar 18, 2004 09:23 AM
J Money
14
May 1, 2003 06:29 PM
Quik89Si
11
Apr 23, 2002 08:29 AM
