my b18 build up...i need help
Old Apr 4, 2009 | 03:26 PM
kiTman's Avatar
New User
Default my b18 build up...i need help
Ok here is the story i was wheeling with my buddies and we came across a acura integra in a field and i didnt think anything of it so he was crawling on the car with his jeep and for the hell of it i decided to pop the hood and when i did i saw a nice b18a1 sitting in there so the next day i took my truck up there ad pulled the motor out and brought it home! when i pulled it, it had 197k on it and it looked really clean even taking it apart the head gasket was good it had good oil, it was full or coolant, here are pictures all broke down
Now my first plans are to have the deck leveled, cylinders honed, and crank balanced if i use the stock crank. I also want to put the b16 head on it so it will be vtec, this will be my first import motor build so i am a little confused i really want to be inside the 200whp range here is a small parts list so far
B16 head
Not sure on the valve train
Skunk2 intake manifold
stock injectors and TB/ or larger injectors with walbro fuel pump
Skunk2 cam gears/ mabye new cams
stock 3 layer headgasket
cold air intake
MSD cap and coil
B18A1 block
stock ls rods with arp rod bolts
stock ls crank balanced
Not sure on pistons and rods if i want new stock or aftermarket
ian1006
Appearance Build Threads
69
Jan 18, 2012 05:14 AM
ibemike
May 16, 2006 03:00 AM
philibuster
Oct 16, 2005 06:54 PM
white86hbk
63
Nov 30, 2002 09:02 AM
