Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 ac issues
Old Apr 4, 2009 | 03:20 PM
hawaiiancb74's Avatar
Default 03 ac issues
03 4dr ex auto
problem: ac does not work
abnormalties noticed: ac button still turns green when pressed, rpm does not jump when ac button is pressed, no noticeable engagement, ac fan does not come on, blows ambient temp air.
Have checked: all fuses and relays, ac transistor on blower motor, belt.
i think it may be the thermal protector [ 38908-PLM-A12 ] on the compressor, ive heard of people jumping the two blue wires and the ac working... ide opt to replace the part instead.. apparently its a common failure but when searching on here for it i didnt see any mention of it.
wondering if anyone else has any ideas before i go rippin into this thing
Old Apr 4, 2009 | 03:30 PM
toyomatt84's Avatar
Sanji
Default Re: 03 ac issues
Have you ever checked the system to see if it needs a re-charge?
Old Apr 4, 2009 | 07:50 PM
mitchie55's Avatar
Could be a few things, compressor could be damaged or u could have a leak in ur condenser and thus the gas has leaked out.
My dc5 had the same issue which was resolved by finding the leak in the condenser, sealing it and re gas and thats it.
Hopefully thats ur issue as well because a compressor cna be pricey
Old Apr 5, 2009 | 05:47 AM
well the only reason i threw recharge out was because i figgured even if it was low or had a hole that it would still engage. my dc5 did when it had none in it.
rovafa2002
Dec 10, 2013 02:44 AM
xxjokoxx
Aug 23, 2010 12:51 AM
crazyguy
Aug 10, 2007 06:45 AM
vietnogi
May 24, 2005 08:01 AM
Demon R
May 23, 2004 10:46 PM
