dohc zc header ??s
Old Apr 4, 2009 | 10:51 AM
kojack_0's Avatar
Default dohc zc header ??s
my crx si has a dohc zc swapped in.
and at the moment, i have a jdm dohc zc upper header connected to a 95 civic ex lower header. this setup is 4-2-1 style.
the problems with this setup is that it scrapes when i hit those little hills in the middle of the road and when i hit bumps. my suspension isnt even that low since my wheels arent even tucking.
now i have a dc sports d-series header available. and people say it bolts right in. but the ports for dohc zc is 3mm slightly off than a regular single cam.
my question is how much bigger ports are the dc sport headers compared to stock header?
if its 3mm off should i still bore out the dc header?
Old Apr 4, 2009 | 11:17 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: dohc zc header ??s
I just had my d-series DC header port matched.
Old Apr 4, 2009 | 11:21 AM
kojack_0's Avatar
so i do need it port matched?
will 3mm matter anyways?
im only using my car as a daily. only thing it has is a whole dc sport cat back exhaust. its n/a. on stock internals.
Old Apr 4, 2009 | 11:23 AM
InvaderTrax's Avatar
The ports are the same size, just higher up. Just grind out that little bit and you'll be fine. Even if you don't grind, it'll still work
Old Apr 4, 2009 | 11:29 AM
kojack_0's Avatar
thank you.
Didly
Jan 6, 2006 07:19 PM
1badrex
Mar 8, 2005 05:54 PM
mr2
Jul 6, 2004 09:15 PM
91teg
Mar 6, 2004 06:32 AM
