Which OEM cam gears are compatible with CTR cams?
Old Apr 4, 2009 | 07:59 AM
blackcivic11's Avatar
Default Which OEM cam gears are compatible with CTR cams?
im pending on a purchase of CTR cams (both) for $350 but it doesn't come with cam gears. Which OEM gears can i use? are all B series cam gears compatible?
this is urgent because he will not hold them for me so please i need help ASAP
Old Apr 4, 2009 | 09:06 AM
projectTeG's Avatar
Default Re: Which OEM cam gears are compatible with CTR cams?
all b-series gears are pr3 gear any will work.
Old Apr 4, 2009 | 09:19 AM
ok good thanks
I can get some JG cam gears for 100$ is it worth it?
Old Apr 5, 2009 | 08:35 AM
C_Rock77's Avatar
Originally Posted by blackcivic11
ok good thanks
Depends on your engine package.
Cam gears allow you to dial in overlap and adjust cam timing. If your setup is pretty much stock, you're probably not going to see that much of a gain.
IDK what GE gears sell for. If it's a good deal, it wouldn't be a BAD thing to have.
sgnlab
Aug 31, 2010 05:11 PM
AllmotorGSReg
Nov 17, 2009 12:07 AM
vacuuum
Feb 12, 2008 08:35 AM
killaBc1
Jan 30, 2005 11:35 AM
JdmLsPwr425
May 4, 2004 03:02 AM
