help with door panel!
Old Apr 4, 2009 | 07:42 AM
patrickstar's Avatar
Default help with door panel!
so im about to swap some new doors in my car but i also need to swap in my old panels to the new door. i've only tried to take my panels off once and i ended up bending the metal clip retainers on the window sill straight or i created bigger holes or it.
my question is how can i take them off without damaging the clips? thanks
also, i've never taken a door off before, i looked at it and it looks like simple bolt on/offs right?
Old Apr 4, 2009 | 08:11 PM
Lil Rick's Avatar
Default Re: help with door panel!
the door panels are easy like 9 screws and then pull the finger cup out and then slide the door panel up so u want bend the black piece that goes by the window and yes the doors are jus bolt on bolt off kinda thing the only thing is the plug tht goes from the body 2 the door for ur speaker wires and everthing jus unplug it and 4 12mm bolts
oh and if im not mistakin u have 2 take the fenders off 2 take the doors off
Old Apr 5, 2009 | 12:51 AM
thanks!
hmm when i tried looking at it, it looked as if i had to take the door off first to take the fender off. that sounds really dumb though but those bolts for the door hinges are so hard to get to in between the door and fender gap. theres also two bolts for the fender in between that same gap that i also cant get it.
advice please? thanks
Old Apr 5, 2009 | 02:36 AM
DCFerris's Avatar
you dont have to take the fenders off to take the doors off
Old Apr 5, 2009 | 10:21 AM
oh how do i get to those bolts in between the fender and door then?
Old Apr 5, 2009 | 04:55 PM
88_acED6's Avatar
why are you taking the doors off? i thought you were just doing door panels....88-89 0r 90-91?
Old Apr 5, 2009 | 04:59 PM
stoddard's Avatar
open the door and use a extenchen
Old Apr 5, 2009 | 07:29 PM
oh i was asking about how ot take the panels off without breaking/bending the clips because im swapping doors and the new door has no panels. it's a 91. i think im good with taking the panels off. taking the doors off, i think im okay with that too. now my problem is swapping the door locks. is this easy to do? i looked behind at the new door and it looks really complicated. haha
Old Apr 5, 2009 | 08:15 PM
~sp33~'s Avatar
EFB055
They're a pain in the ***. You'll get it after alot of fiddling though.
Old Apr 5, 2009 | 08:25 PM
lol dang i just dont wanna break or mess up anything.
i ask all these questions cus i need to get all this done in a short period of time us its my only way of transportation. haha. dont wanna drive around without a door.
Old Apr 5, 2009 | 08:44 PM
~sp33~'s Avatar
EFB055
From memory the locking mechanism is attached to the door handle, which makes it nice and difficult to work with.
Old Apr 5, 2009 | 08:54 PM
can i just take the door handle off the door and work with it like that? cus i saw a long line thta connected from the door handle to somewhere to the bottom of the door. i cant find a DIY for it either.
Old Apr 5, 2009 | 09:49 PM
~sp33~'s Avatar
EFB055
There are metal rods connected from the latch to the handle, and i couldn't take them apart. I found the best way to remove the assembly was to take the handle out from the outside of the car (standing outside, take the whole assembly through).
The metal rods are what make it difficult, there's very little leeway in them.
Old Apr 5, 2009 | 10:02 PM
ah i dont know how im gonna do this. haha. i might do what you did. ill take a look at it again tomorow
grape1161
14
Mar 30, 2010 12:28 AM
baconcrx
Welding / Fabrication
Apr 28, 2006 08:55 AM
LazJDM
Apr 21, 2006 04:30 PM
91hondacrx
Aug 19, 2004 06:53 AM
snake01
Jan 11, 2002 09:06 PM
