Emergancy brake light on... etc
Old Apr 3, 2009 | 11:19 PM
foshizzinit's Avatar
New User
Default Emergancy brake light on... etc
I have a white 2000 integra ls stock 70,000 miles brake pads, oil, clutch change at 60,000miles. this happen to me a couple of times. I start up my car and drop the emergency brake. i drive off and my emergency light is on even though i let go of the emergency brake. after driving about 5 minutes i push my regular brake and it goes away... I asked my friends about this and they said check my brake fluid. i checked it and its fine. What is causing this problem?
Can you also suggest some OEM fog lights websites?
Old Apr 3, 2009 | 11:31 PM
BlueIntegraBoy's Avatar
Default Re: Emergancy brake light on... etc
Top off the reservoir to the max line with brake fluid.
I picked up my OEM fogs from Park Acura:
http://cgi.ebay.com/New-OEM-98-01-In...1%7C240%3A1318
Old Apr 4, 2009 | 05:41 AM
paton5g's Avatar
If that light is on and your brake fluid is good, you may have a sticky switch under your emergency brake. It makes the light on the dash come on when you pull it up so you don't forget the e-brake.
Old Apr 4, 2009 | 08:53 PM
keepinitrehaal's Avatar
i have the same problem
Manmeetsingh
May 20, 2014 08:06 PM
adamcm16
Apr 10, 2014 05:07 PM
redacura
Dec 6, 2008 04:53 PM
Jaydeep
Jul 27, 2004 08:00 AM
Tench
May 11, 2004 10:23 AM
