dirty head lights need Mr. clean
well like the title reads my head light are real dirty they look kinda yellow and i decided to do something about it. does any one know some kind of liquid or some cleaner thats good for that? thanx.
i know, i hate that look, i would just buy some new ones from honda. but i'm farly sure there are some plastic polishes out there. how do the look from the inside? - through the bulb hole? is the yellow a top coat on the outside only?
x2. I used 1000 grit, 1500 grit, and then 2000 grit sand paper. Then I used rubbing compound, Scratch & Swirl remover, and then a plastic polish on my JDM headlights and they came out looking like brand new.
go to autozone or pepboys and buy this it works great
Have it professionally detailed. Mention you want them to clean your headlights, and then you'll not only have clean headlights, but a mint *** car all around.
If u have access to air napa sells a kit by 3m that works great.it costs like 3hundred but u can make ur money back quick and then some and it works great. My shop charges like $125 for the service
I bet anyone $5 that Mothers aluminum and mag polish will work real good!!, i use it everytime and it works great! and you can get the small can at any walmart! and its like $6.00!!!!
im going to give this a try and see how it comes out. ill post some before and after pics so you guys can see. thanks alot people.
I've used it on my left side headlight after I got a new right side headlight, and I honestly cant tell the difference between the two now.... So I'd say PlastX works good
i also have the yellowish headlight on the passenger side. I just tried the Megiuars plastc x but its still yellow. I'm thinking of wet sanding next. sucha pain to remove to assembly though to try it
buy the 3m kit that autozone sells, it comes with everything to wetsand and then polish using a home drill
i used it and it worked great
