ZC head modifications
I have 3 stuck valves on the ZC motor I got from sunrise enterprises, the short block is good. While I'm having the Head fixed, is there anything I can do to it to increase performance(head wise) without building up the lower end or F-ing up factory computer settings and still maintaining a smooth idle. This motor is going to be used in a rally car, Which is why I chose the ZC over a B series(ground clearance).
Sean Burke 91 CRX
Sean Burke 91 CRX
You could try porting the intake, although the ZC intake is pretty good to start. Since you'll have the head off, you could try getting all the plugs synced up
krysted9354
May 17, 2009 09:47 PM
CRX_RUS2
Nov 26, 2004 12:52 AM
