Weisco Ring Compressor Question
Old Apr 3, 2009 | 06:41 PM
DulinDragons's Avatar
Default Weisco Ring Compressor Question
I did my research on here for tapered ring compressors. And i plan to get the Weisco 81.5mm compressor. My small quick question is, what size do i get? I went online to summitracing.com and found two kinds. One with an 81.5mm, but it says minimum bore size and max bore size. Thats where i get confused. My best guess would be the 81.5mm as the minimun bore size. I just dont wanna choose the wrong one.
Old Apr 3, 2009 | 08:25 PM
Rocket's Avatar
Default Re: Weisco Ring Compressor Question
Some are adjustable with a hose clamp to adjust size. Then there's the one size only with no hose clamp.
Old Apr 4, 2009 | 06:14 AM
mar778c's Avatar
Community Builder
Community Influencer
This is a little costly, but I have the wiseco compressers sizes ranging from 81 to 82 mm and 84 to 85 mm. I tried the adjustable once with a bad result. If your block has a 81.5 mm bore and hone then get that size.
The tapered sleeve makes it very easy to install a piston.
Old Apr 4, 2009 | 06:54 AM
b19coupe's Avatar
The tapered piston ring compressors made by ARP and Wiseco are easy to use and practically foolproof. Just order the size that matches your bore size.
Mr. Vapor
Sep 12, 2005 11:12 AM
luckypon7
Sep 10, 2004 08:37 AM
GreenR
Jan 29, 2003 03:39 AM
