17' rims on Honda civic 2004 Vibrating
Ok got 17' rims with for Honda Civic 2004 4dr
Brand: Nexen Tires
Model: N5000
Tire Size: 205/40/17
The only problem is that I installed the right rim on the left side and left on the right side but only for the front wheels, back wheels were installed properly...I later changed them and put the right rim on the right axle and vice versa, I do see that the wheels are vibrating after 100 kms on hwy Now, any suggestions
Do you think if the balancing is out?
Brand: Nexen Tires
Model: N5000
you need hub centric rings for a proper fit thats another 50 bucks . you should have got smaller rims they look and perform better not to mention cheaper .
oh i have the hub rings installed on them...its light vibration that is always there but i just donno why, i guess going with smaller rims would have been a better idea
hmmm i guess its a bad balance job take it back and bitch maybe get it done free or maybe there defective rims.or evan a defective tire.????????that sucks.
I am having the same problem! I have 17 ADR wheels with the same exact tires. I've noticed that the wheel weights which stick to the inside of the wheel have flown off. Check that out first!
