b series parts
Old Apr 3, 2009 | 09:17 AM
EG6_978's Avatar
Default b series parts
i kno b series transmission can fit on any b series motor. can the b series fuel injectors, alternator, and starter do the same thing? what would be the best stock fuel injector for b16a2
Old Apr 3, 2009 | 09:47 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Re: b series parts
hmmm, best stock fuel injector?
im gonna take a shot at this one, the stock ones....
are you saying you want stock size injectors but an aftermarket product? if so thats pointless. Also, what other mods do you have that are sufficient enough to require upgraded fuel injectors. If you just throw them in there, you may as well take a dump on your a/f mixture, gas mileage, and long term, your piston rings....
Your stock ones are 270cc i believe....ive got a **** load of motor work and im only at 310cc...
Old Apr 3, 2009 | 09:56 AM
00b20vtecoupe's Avatar
i think he means wat injectors that came on a car stock can be put on a b16 that are bigger... usually ppl grab h22 injectors they r slightly bigger but as far as starters all b series should work together. alternators i belive b16 and gsr r same but ls is dif.
EG6_978's Avatar
im not upgrading. i bought a longblock with no injectors and alternator. im just wondering which injector will fit and make it runs fine, and if all b series alternator is the same
Old Apr 3, 2009 | 09:59 AM
EG6_978's Avatar
thanks
Old Apr 3, 2009 | 10:02 AM
i have stock b16 injectors and alternator sitting around... ftw
jcoleman134
May 19, 2016 09:04 AM
AMZ GS-R
Jun 14, 2004 12:22 AM
Mucackus
Apr 24, 2002 05:29 AM
civbeater90
Apr 8, 2002 09:08 AM
