open header??
Old Apr 3, 2009 | 06:08 AM
96b18c-r's Avatar
Post open header??
I have a 96+ spec Type R in my civic coupe
I currently am waiting unti paycheck to order my new exhaust...
But i have a new header sitting in my garage. if i run open header for 1 day is there any risk to my motor?? someone once told me that it would **** it up because of not enough back pressure but not so sure that person is correct?? just some quick feedback...... thanks
Old Apr 3, 2009 | 06:33 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: open header??
lol, yeah that lack of back pressure will doom your motor.
Old Apr 3, 2009 | 09:08 AM
Adam_b16a's Avatar
no, you will be fine. i rode around open header all the time when i changed exhaust setups.
Old Apr 3, 2009 | 12:33 PM
90SiReX's Avatar
i believe u can burn valves runnning open header.
Old Apr 3, 2009 | 12:42 PM
Rocket's Avatar
Let's hope that you don't sit in traffic as you can 'accidentally' induce 'sleepy time / dirt nap' from carbon monoxide fumes that build up under your car and find its way into the cabin. There's good reason for tail pipes to protrude past the rear bumper to avoid this very situation.
Old Apr 3, 2009 | 01:09 PM
Combustion Contraption's Avatar
Can you explain to the class how runnning open header would lead you to burn valves? Why do none of the pro AM cars burn valves? F1 cars dont burn valves , and those engines turn 18k rpm for about an hour and a half.
Old Apr 3, 2009 | 01:49 PM
h224thgensedan's Avatar
I wonder who started those two rumors about the valves burning and the backpressure. I drove my car from my house to my friends house (2 miles)open header, just to get the exhaust on. By the time that I got there I couldnt wait to get out and get some fresh air.
Old Apr 3, 2009 | 01:57 PM
AltimaXX's Avatar
I've driven around open header plenty of times...it won't "hurt" anything aside from your hearing.
Old Apr 3, 2009 | 04:40 PM
Teamdiesel's Avatar
I drive around open header just before, during, and shortly after every race event. There is NO exhaust fumes that enter my cabin, the noise is bearable after a while, and you WILL NOT burn valves. Open header only gives more power.
Old Apr 3, 2009 | 04:52 PM
DC_Legacy's Avatar
I dont know, but apparently its an old rumor because my dad told me that when I was a kid after removing the stock muffler off a gocart motor for a straight pipe, lol...
I doubt this has any real bearing on the exhaust valves. The only way I could imagine this happening is if fresh air could some how make its way around the pulse of streaming exhaust to provide oxygen to a glowing hot exhaust valve.
Old Apr 3, 2009 | 05:23 PM
SMSP's Avatar
Originally Posted by Teamdiesel
...... the noise is bearable after a while, ........
Because you are loosing your hearing!
Fink29
15
May 18, 2009 03:15 PM
PPLH8R
Welding / Fabrication
14
Jan 20, 2008 11:58 AM
SlammedDC2
Nov 19, 2006 10:37 AM
AintegraA
Dec 11, 2003 11:43 AM
DubyaAye
Nov 13, 2003 04:56 AM
