ED8/ED9 Suspension Differences
Old Apr 2, 2009 | 01:11 PM
Jay SWAT's Avatar
Default ED8/ED9 Suspension Differences
Is there any difference between the ED8 and ED9 as far as the suspension goes?
I'm trying to find the correct suspension from Tein. I just bought a rear disc setup off of a 91 si. But i still have my stock 88 setup for the front. Tein sells a different setup for the ED8 and ED9 and i'm wondering what the actuall difference is
Old Apr 3, 2009 | 11:46 AM
Tyson's Avatar
Default Re: ED8/ED9 Suspension Differences
i dont even know what ED8 and ED9 mean, but it may just be a difference of rear lower control arm styles.
theres no other reason the suspension would be different.
Old Apr 3, 2009 | 04:13 PM
kojack_0's Avatar
ed9 = crx si
ed8 = crx 'dx' or hf.
i dont think itd be any different from each other.
88 crx came with a type r type rear lca. unless you dont wanna keep that [imo you should] any suspension from 89-95 crx/civic should work. if you do decide to keep the type r type rear lca your going to need a different type of rear shocks, the same ones you use with the actual type r rear lcas.
dont know if you get it or not. but i have a 89 crx si and im using 95 integra kyb agx with coilovers and it works great.
also keep in mind that if you wanna use shocks from the years 92-95 youre going to have to use the front shock 'fork' from a 92-95, cause it has a wider shock than the 89-91.
type r/ 88 crx suspension setup looks similar to this:
regular 89-95 civic/crx suspension setup looks similar to this:
alright, im not sure if im making any sense to you. haha.
gob4show
Oct 2, 2005 04:53 AM
mechengine
Jun 5, 2004 08:16 AM
I3ackfire
11
Mar 17, 2004 09:19 AM
Urban Business
Feb 20, 2003 10:09 PM
thecorey
Nov 23, 2002 06:23 PM
