Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 Honda Civic P2176 Code
Old Apr 2, 2009 | 12:05 PM
toddfhas's Avatar
New User
Default 2007 Honda Civic P2176 Code
I have a 07 Civic that I have purchased that has been in an accident. It appears as if it was lightly rolled over. The car will start and runs for about 5 seconds before it shuts back off. It is showing a code of P2176 "Throttle Actuator Control System Idle Position Not Learned". I am figuring that it needs to run for a little while before it reprograms itself but it will not run long enough. Any sugjestions or info would help.
Thanks, Todd
Old Apr 2, 2009 | 09:18 PM
miketat594's Avatar
Default Re: 2007 Honda Civic P2176 Code
you can try disconnecting the ECU, let it sit for a while unplugged and then try it..also make sure you see the green immobilizer key come up on the dash.
bEnJiX
16
Mar 29, 2014 08:45 PM
edmondssesay
Apr 19, 2011 02:15 PM
goob
Acura TL, RL & ZDX
Apr 18, 2006 10:47 AM
