gsr cable trans / B16 head / ACT clutch / CD changer / EK ignition, combo switch, etc
92 gsr ys1 cable trans_$450
- about 150k
- sometimes theres a slight scratch going into 3rd at high RPMs but i never had a problem getting into 3rd. i used regular engine oil for the trans so it might go away if you use gm syncromesh
- no trans sticker but i GUARANTEE its a ys1 from a gsr
- uses same clutch for all B-series hydro trans
http://www.ff-squad.com/tech/temp/Bgears.htm
http://www.fatboyraceworks.com/gears/
**SOLD**act performance street disc & xtreme or hd pressure plate
13" VX wheels w/ firestone winterforce snow tires_$225*no_shipping*
sprayed painted black (not that good of a job) 13" VX wheels with brand new 155/80/13 firestone winterforce tires. only reason im selling is cause they wont clear my 00 EX front brakes on my EK hatch. reviews on tirerack.com rate them at 9 in the snow
http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Winterforce #Survey
b16a (pr3) head_$450
- 1999 b16 head
- comes with stock b16 cams & gears, cam caps, vtec solenoid & valve cover
gator stage 2 b-series axles_$350
-fits any b-series swap using 90-93 intermediate shaft
-perfect for all motor & slicks, ran a 1.8 60ft (THATS AROUND WHAT AWD CARS HIT) with 22" slicks no problems
PS3 games:
- silent hill_$45
- assassin's creed_$30
- fear_$30
OEM honda cd changer_$70 shipped
- came from my 96 civic dx
- comes with wires
pioneer cd changer_$50 shipped
- comes with wires & remote
90-93 integra RS doors_$20 each door
- comes with glass & inner door panel
- one door is rusty
90-93 integra under dash fuse box_$25 shipped
- no fuses
2 90-93 integra under hood fuse box_$20 each shipped
- one with ABS
- one without ABS
- no fuses
2 90-91 OBDO engine harness_$50/auto $60/maual
- manual
- automatic
96-00 civic steering wheel w/ airbag_$100
- beige
- cruise control
96-00 civic ignition cylinder & switch_$70 shipped
- comes with key
- brand new, replaced on my aunts car (thieves tried stealing it) then i found out the steering shaft was bent so i had to find a used steering shaft and it came with an ignition so i just swapped out the key tumblers
96-00 civic combo switch_$30 shipped
- headlight switch
- turn signal switch
B18A engine disassembled_$150
-comes with block, crank, rods & pistons, oil pan, oil pump, water pump, head, cams, intake manifold, valve cover & all the misc parts to put everything back together
-had about 130k on it
B18A cracked bare block_$50
- perfect for sleeving
- crack in #3 cylinder
- comes with main caps & bolts
B17A bare block_$75
- over bored .25mm
- light nick in cyl #1, might need to be over bored to 81.5mm
2 stock B-series cam gears_$5 per pair
2 sets of B16 camshafts_$40 per pair shipped
99 TL HID igniters_$60 shipped
- still need D2R bulb & inverter to work
no name brand rear lower tie bar_$10
- came of an EG 4dr but i think it will fit any honda
momo hub_$50 shipped
- hub fits EK / DC5 / EP / AP / PRELUDE
94-01 integra 2dr passenger side window regulator_$35 shipped
- honda part no. 72251-ST7-J02
- used but in good condition, comes in honda bag
92-95 civic 2dr driver side window motor_$25 shipped
- honda part no. 72255-SR3-A02
97 CL & 94-97 accord F22 intake manifold gasket_$7
- honda part no. 17105-P0A-A02
- brand new
PAYMENT
i am verified from paypal
https://www.paypal.com/us/verified/p...oy%40aol%2ecom
VOUCHES
darkteg, importboi22, explicit racing, jeremyg2teg, acydphryk, dancomer, straightline, biglew, youngkow, svw, chitownEG, akiraboy, b20mike, n1div, dunkd, jdmcraze, blimp, jdm r, got utensils, knightnam real slow em1, relic1, hypropulsion r, jdm j03, acuratilidie, redheadracing, akiraboy, hayes, j's 94 accord, joke12, sohc_brian, maxwellmercer, midwestautoworks, gabebauman, bokals, hondaon18's, sol_1, jdm-95_ls, wickedplastikman, gong show, luv2h8
- about 150k
- 1999 b16 head
PS3 games:
- silent hill_$45
- fear_$30
- comes with wires
- one door is rusty
- no fuses
- one with ABS
- one without ABS
- no fuses
- manual
- automatic
- beige
- cruise control
- comes with key
- headlight switch
B17A bare block_$75
- over bored .25mm
- brand new
PAYMENT
VOUCHES
DjFreeze
Oct 24, 2002 10:42 AM
