engin roughness
Old Apr 2, 2009 | 08:26 AM
PTVDesign's Avatar
Icon2 engin roughness
F22B DOHC engine 96 year
uneven work, checked the vacuum tube.
checked sparkplugs no breakdown
new spark new fuel
all the same roughness
http://www.youtube.com/watch?v=CBKAjepa914, who can tell what the problem might be?
Turnover does not fly, at least for tahomtre not visible.
but judging by the tone and the measured voltage of the roughness is observed
Old Apr 2, 2009 | 09:43 AM
Brad_and_the_acc's Avatar
Default Re: engin roughness
http://www.sendspace.com/file/v51s6e
What is this^^^^?
I am not sure what your problem is because I dont quite understand you and what your getting at. The "file" thing is DUMB, There is NO WAY IN HELL im going to download some bs I have no clue where is came from. If its a video post it on youtube and give us the link.
Old Apr 2, 2009 | 10:30 AM
bdmlilburn's Avatar
how old is your oil? might need an oil change
Old Apr 2, 2009 | 05:00 PM
PTVDesign's Avatar
What is this^^^^?
sorry, look again
Old Apr 2, 2009 | 05:02 PM
PTVDesign's Avatar
new oil 0w40 Mobil1 Synth, 600 miles
Old Apr 5, 2009 | 06:04 PM
What RPM is the car idling? In the Vid it sounds like it could even be an exhaust leak, like a bad exhaust leak. Have you checked compression?
Old Apr 6, 2009 | 03:09 AM
PTVDesign's Avatar
I turned off the MAP sensor and the engine began to work smoothly,
change the map sensor is not give result
Old Apr 6, 2009 | 11:17 PM
CG6Accord8o1's Avatar
clean ur throttle body and spray the butterfly.
Old Apr 6, 2009 | 11:21 PM
ddipre11's Avatar
whats an engin?
Old Apr 6, 2009 | 11:38 PM
PTVDesign's Avatar
throttle body is clean.
engine is F22B DOHC JDM (it's similiar USDM H23A)
http://www.youtube.com/watch?v=-LfyXS8uxyA - without iacv
http://www.youtube.com/watch?v=uy3OzgPHzzo - with iacv
http://www.youtube.com/watch?v=hExRn1k0IxM - with iacv (a/c, light, role wheel)
Old Apr 8, 2009 | 10:59 PM
PTVDesign's Avatar
probleme located in bad wiring to O2 sensor, now it's all ok thanks all
AmyNxDx
Honda Motorcycles
Sep 14, 2010 02:36 AM
s bourgault
Feb 3, 2004 02:40 PM
ckkl
Mar 25, 2002 04:43 PM
