Honda S2000 Honda S2000
S2000 cluch write up complete, check it out
Old Apr 1, 2009 | 06:51 PM
Master23's Avatar
Default S2000 cluch write up complete, check it out
This write up covers Honda S2000 2000-2004 models: clutch pedal, master and slave cylinder replacement, pressure plate and clutch disc removal, flywheel inspection and replacement and release bearing inspection. Whew!
Honda S2000 clutch and flywheel inspection and replacement.
Old Apr 1, 2009 | 06:52 PM
Master23's Avatar
Default Re: S2000 cluch write up complete, check it out
Corrections and critiques welcomed. I'm debating if I should do one on a overhaul of the tranny but it'll totally kill me so I guess we'll see if there is a demand for it.
Old Apr 1, 2009 | 06:54 PM
AP1_man's Avatar
could of spelled clutch right at least
Old Apr 1, 2009 | 06:56 PM
Black S2K's Avatar
too lazy to read it but looks ok. its no so much of a bitch to change the actual clutch and or flywheel its just a bitch to thet the tranny off the car the two top 17mm bolts on the belhousing that connect to the block are hard to get two and impossible to removbe without a swivel socket
f20cmx5
Dec 15, 2009 12:38 PM
AnthraxVX
Honda S2000
27
Mar 20, 2008 10:41 PM
Type S Zero
Honda S2000
Feb 2, 2003 11:15 PM
