Honda S2000 Honda S2000
Ap1 engine noise help!!!(ticking/rattle)
Old Apr 1, 2009 | 06:20 PM
Ryan111987's Avatar
Default Ap1 engine noise help!!!(ticking/rattle)
delete
Old Apr 1, 2009 | 06:55 PM
AP1_man's Avatar
Default Re: Ap1 engine noise help!!!(ticking/rattle)
hmmm...valve clatter perhaps. when was your last valve adjustment?
Old Apr 1, 2009 | 06:59 PM
Black S2K's Avatar
^ what he said and its prolly your tct(timing chain tensioner) its gotta be one of the two so get a new one cause they do go pretty often and get your valves adjusted. dont throw out your old tct cause you can reuse it and it will be fine you just gotta get that worm screw/shaft thing inside sandblasted.
Old Apr 1, 2009 | 07:15 PM
Ryan111987's Avatar
i have been finding a lot of random info regarding broken or cracked retainers... causing the valve to be out of place... i haven't had the valves adjusted in the 13,000 miles (year i have owned it)
Old Apr 1, 2009 | 07:31 PM
Black S2K's Avatar
have you over reved your car? the reataoners crack if you money shift or just **** up in general and over rev. A cracked retainer wouldnt make noise it would just drop a valve over time and you need a new motor.
Old Apr 1, 2009 | 07:35 PM
AP1_man's Avatar
this reminds me, i need to do my valve adjustment...i got mad clatter on the exhaust side =/
Old Apr 1, 2009 | 07:36 PM
Black S2K's Avatar
^x2 but i think its mostly the header cause its not heat wrapped like my old one was
Old Apr 1, 2009 | 07:40 PM
AP1_man's Avatar
i think it resonates through the header...i hate when people ask me "what's that noise?" ugh.
Old Apr 1, 2009 | 07:58 PM
Black S2K's Avatar
no one asked me yet i just hate hearing it esp when im ideling next to a wall/fence and or drving by one in low rpms
Old Apr 1, 2009 | 08:07 PM
AP1_man's Avatar
^^^x2 luls.
Old Apr 2, 2009 | 08:17 AM
Ryan111987's Avatar
how can I check the tct?? I have basic knowledge, but I really don't want to start disasembling my engine in my tiny garage with limited tools??? where would you recommend I bring the head to have it looked at and or parts replaced.. I don't really want to go to a dealer.... performance shop??? or engine place??? thanks guys
Old Apr 2, 2009 | 08:46 AM
Black S2K's Avatar
you cant really check the tct you just remove it and put on your new one its roughly a 20-30 min job. and i can really recomend where to go and get your retainers checked out cause most shops/dealers wont even know what they are looking for. your best bet is to go to s2ki.com and research they have information on there about everyhting how to change the tct how to adj your valves how to check your retainers.
Old Apr 2, 2009 | 03:47 PM
Slammedsilverstone's Avatar
Yes and to remove the head would be a large waiste of time to diagnose any of those problems. The tct is 2 bolts and a 4 dollar nut and bolt you must buy. and the valve spring retainers can be checked with the VC off and thats 5 or 6 10mm bolts, two cam sensors, and a pcv. O and your coil packs one 10mm each and a 6mm allen head for the coil pack cover. no biggy at all. fo real.
Old Apr 2, 2009 | 03:58 PM
Ryan111987's Avatar
what do you mean about that 4 dollar bolt? i need to buy that just to check the tct?
Old Apr 2, 2009 | 04:09 PM
Yes sir I have the package still for the nut that you need for it. It is a M5-.80 nut and you will need the bolt to go with it the bolt is about 2.5 inches long. The bolt goes in place of the valve you remove from the TCT. the bolt threads into the worm gear and you jam use the jam nut you purchased to relieve pressure from the TCT. after doing this you can just tap it out no prob. I bought everything from Lowes. There is a right up on S2ki for more info.
Old Apr 2, 2009 | 04:21 PM
Ryan111987's Avatar
thanks Slammedsilverstone, do u think that the tensioner could make that tick/rattle?
Old Apr 2, 2009 | 05:59 PM
bigmacnfries's Avatar
haha - i have exactly the same - got a little louder after i added my j's header
Old Apr 2, 2009 | 06:23 PM
When the TCT goes bad it sounds like a card in bike spokes or a rattle how ever you want to discribe it. Like someone said before though you can salvage the worm gear by sandblasting it. Basically when your TCT goes bad its just exssesive wear between the piston that rides on the timing chain guides and the worm gear thats in that piston. By sandblasting the worm gear you add friction between the two. This means that it takes more force to depress the piston and this means that your chain stays tighter longer. and you save about $150.00 .lol
Old Apr 3, 2009 | 01:52 PM
Ryan111987's Avatar
well i have a tct on the way, so ill let you know if that does the trick next week... im also going to adjust the valves. thanks
Old Apr 7, 2009 | 01:59 AM
riceball777's Avatar
timing chain tensioner most likely. i just had to change mine and i'm at 60 k miles.
i thought i had valvetrain noice but it eneded being the timing chain tensioner. its a very common probalem for the s2000.
Old Apr 10, 2009 | 03:09 PM
Ryan111987's Avatar
well.... the new tensioner is installed and i still have the same noise.... i posted a video on youtube maybe someone will recognize the sound... thanks
http://www.youtube.com/watch?v=nxKX9...&feature=email
Old Apr 10, 2009 | 08:08 PM
PRS Mike's Avatar
New User
Mine does something kinda close... but only on "warm" start ups'....???It "clicks" with the start revs and slowly dissapates after time. Well, at least I don't hear it anymore... anyway, it NEVER does it when it's cold. ??? anyone??
Old Apr 10, 2009 | 08:50 PM
AP1_man's Avatar
dude...sounds like rod knock, congrats
Old Apr 10, 2009 | 11:59 PM
b20integrapower's Avatar
lol. that isnt a tct. that is rod knock. Are you new to s2000's? Make sure you refill your oil. Most of the older models burn oil. I bet you were VERY low.
well i apologize for laughing...it was just funny to me because i was expecting a bad tct sound, but then i heard that and spit up my drink because i wasnt expecting it...sorry =(
