Which one should I change?
Old Aug 14, 2002 | 10:20 AM
turtleb16a's Avatar
Default Which one should I change?
I have Skunk2 coilovers and tokiko blues. The ride is bouncy.... my question is this, which should i change? some say its the coilovers, other say it the blues.... a buddy of mine has the coilovers and stock springs and its bouncy but not as bad as mine. another buddy has the blues with eibachs and his ride doesnt seem bouncy at all.. have a 1.5 inch drop.
getting old, maybe i should buy a lexus.... ha ha ha.
anyways, any help appreciated....
Old Aug 14, 2002 | 11:03 AM
EF_LSVtec's Avatar
Default Re: Which one should I change? (turtleb16a)
your Coilovers make it bouncy, but the Tokico blues, people say, is one of the worst out there...If you just want a smoother ride, I suggest replace your coilovers.
Old Aug 14, 2002 | 11:32 AM
bfrank81's Avatar
Default Re: Which one should I change? (EF_LSVtec)
Why do you say that??
[Modified by bfrank81, 3:34 PM 8/14/2002]
Old Aug 14, 2002 | 12:40 PM
keithv's Avatar
Default Re: Which one should I change? (bfrank81)
its both actually....the shocks can't dampen the stiff springs quick enough so the ride is bouncy.
Old Aug 21, 2002 | 10:24 AM
turtleb16a's Avatar
Default Re: Which one should I change? (breaka_1_9)
breaka,
if i change to say eibach springs, would this make the ride more bearable?
Old Aug 21, 2002 | 10:58 AM
keithv's Avatar
breaka,
if you change the springs to eibach, you must also get a softer spring rate.
personally i would get some koni yellow shocks to try and solve the problem. i know they are expensive, but you might be able to find some used one for sale...
Y-eight
Jul 22, 2011 11:06 AM
BLeSR
May 7, 2010 12:33 AM
JrEk9
Suspension & Brakes
19
Nov 24, 2009 02:26 PM
shelbyEK!
Suspension & Brakes
Sep 17, 2009 08:57 AM
The Si
Sep 28, 2005 10:09 PM
