My Retrofit =)
Only thing I would suggest at this point is try to get some kind of spacer or a piece of tubing and cut it at an angle to match the angle of the headlight housing, then place it on those 4 bolts holding the projector so that the washers and nut will have a flat surface to tighten onto.
So it would be Housing > spacer > washers > nut
